Firefox Users
BitComet has designed browser integration option for popular web browsers to enhance the use of our program, but please use restraint when updating to new major versions of FireFox browser.
When Firefox major updates (examples, 3.0, 4.0, 5.0 etc) are released, you’ll find that many extensions are not compatible, including BitComet’s extensions. When ever these updates are released, or development team begins development on an update which will be noted in the next versions release notes when released.
However, we highly recommend you wait to update to major new releases, not only for this reason, but they usually have other issues that normally take a month or two to resolve.
If you’ve already installed a new FireFox version and don’t want to revert back to a prior version, then why not try CometBird. It’s developed from FireFox source code and is enhanced to meet the needs of the file sharing community. It will co-exist with firefox very well and you may even like it better.
Many users were unhappy with firefox 4.x versions which is probably the reason for the quick release of 5.0. I’d recommend getting the last stable release of firefox 3, which is 3.6.16.
Same is true with Cometbird
You can always try to cheat by modifying the max version in the install.rdf file but it does not always work. For example Firefox 10.0.1 sees bitcomet video downloader 1.31 but it wont detect any video files so i gueese it needs more than that to work
got that idea from people on Mozilla Addons website, i trick used to make old abanndonned addons compatible with newer version of FF. never hurts to try :stuck_out_tongue:
thaaaaanks
yes i use mozila firefox
I only have one question.What’s go wrong with atcomet,i get no connection.Thanks
Atcomet has been fixed. Like all websites, they sometimes require repair, so to be as succinct as possible… The site was down.
It’s now back up.
http://atcomet.com
Thank’s for an explanation!
Thanks :slight_smile:
firefox makes bitcomet use very hard am getting tired from this
In what way does Firefox make BitComet hard to use? Have you tried the (above-mentioned) suggested CometBird?
Hi, in next version, BC will support the latest Firefox and IE version
i m using firefox
Hi There,
Asked this question in another thread, but didn;t get answered.
What is the latest version of Firefox that will most likely work with Bitcomet?
I am currently using FF 26.0 & Bitcomet V1.37.
Has anyone had any luck using Bitcomet with newer versions of FF?
Is there any plan for a new release of Bitcomet in the future?
Cheers
Tim
Hello!! how can you do with Chrome?
If I understand your question, download version 1.38 (or newer), which have support for Chrome browser.
dessertcasino.com You should write about the model/version on the blog. You can expose it’s perfect. Your blog examination should widen your readership.I am really grateful for your blog post. I find a lot of approaches after visiting your post. Great work..looking for affordable and trusted hosting?come and visit
giocarecasino.net I really appreciate the kind of topics post here. Thanks for sharing us a great information that is actually helpful. Good day! nirmala.cutez@yahoo.com
BitComet is a best downloading software. i use it every time.
Manoj Kumar
Online Reputation Management
http://www.areputation.co.uk/
I’m also using firefox.
Regards :slight_smile:
