I only said try to have 3 KB/s for each upload slot. It shouldnt make too much of a difference for you whether its set at 4 or 5. Although the automatic setting puts the max at 5, Bitcomet may never actually open that many slots if you dont have enough bandwidth. If you look in the peers tab Im sure you will only find that 2 or 3 of the peers will have the capital U(uploading) flag. Make sure with that type of connection that you only run 1 torrent at a time, and I think it would be better if you set Global Max Upload Slots to 4 and Global Min Upload Slots at 2.
-I forgot to tell you that my max Dl speed is 128 kb/s also (verry slow I know). That can have an relation with what I want to configure or nothing ?
-My connection bandwidth (Dl/Up) slows down in some moments of the day (it’s to the max during the night), so I can set my max Up speed in BitComet less than 80% ?
