I need help? I’m lost. BitComet will not work. (Port blocked) It’s Either Norton stopping me or it’s Xfinity ISP stopping me from using BitComet. I tried to create a Port Forwarding thru my Xfinity modem. I get IP error when attempting.
You need to set up port forwarding as follows:
Set your computer for a fixed IP number, then set up a post number to that IP
Port forwarding not on a fixed IP will give that error
@ Dano219,
Please do NOT make duplicate posts in the forums.
Thank you.
