HELP FOR SPEED
PLEASE IF ANYONE CAN HELP ME HOW CAN I SPEED UP MY DOWNLOADS I HAVE TRY EVERYTHING
I OPOEN PORTS AT FIREWALL WINDOWS PORT TRIGGER IS THERE SOMETHING ELSE
I USE BITCOMET 0,71
DCL AT 1024K
DOWNLOAD RATE 10KBS
Go back to 0.70.
And you do not need to open ports in your firewall unless that firewall is built into a router.
im havin the same prob mate,i f i find a solution il let u know!!!
Dark_Shroud : U are such an a******, man! People giving u questions because you are supposed to be a technical help. But u always giving non-sense reply and ask people to “search for answer” and ask them to stop typing in CAPs.
What is your problem man? I’ve been finding answers for some questions (same like others), but never found anything helpful, esp from u.
such a d***!!!
What version of BitComet are you using? Do you have a router? What security software are you using?
such a d***!!!
Oh yes, explaining to people that they are using a bugged vesion of BC (0.71 & 0.72) like rexdimos is/was or using programs like Zonealarm that are known for bad behavior. My responces are simple and to the point for people’s specific needs. I no longer bother to give big explanations because people like you never understand them. People who have a problem with my responces are more than welcome to pm me over that matter if they didn’t understand, didn’t aggree, or had some other issue.
So, should I ban this acount of yours that you signed up with today just to give me crap or some of the others with the same IP: ttcer, yingtzi, navasak, hao_zai, iangbird, Abugarcia, devilcatz, kaileonard, en0010, zeta, kasivarama, guruking?
Hi… can anyone give me an idea on how to speed up my download.
im using 0.59. DSL 1024kbps download 10 - 40kbps with Firewall.
Try to get install 0.7 but every time im doing it my Anti-spy shown 5 spyware viruses…
try to uninstall hoping it might remove it, but the viruses are conquering the sistem,
using antispyware Trend Micro 3.0. any brilliant idea :unsure: .
i m using bitcomet7.0 i am havin the same problem my dl speed is ard 20kb/s some even 0kb/s its slow
