help me please
hi, first time post…teehee
anyway, the problem. iv been downloading a file for over 2 weeks now, it has the seed/peer[all] at 8/24[24/330] sometimes more and the speed only gets to around 25-45kB/s sometimes a little more.
i done a speed test and i got 4.81 Mb/s download and 0.37 Mb/s upload
the thing is, a few nights ago, it was downloading at <450kB/s and it wont get back to that speed
My setting are as follows:
Global Max Download Rate: Unlimited
Global Max Upload Rate: 18
Listen Port: 61212
Enabled NAT/Firewall Configuration in ICS/ICF
Disabled UPnP Port mapping (is i have the port forwarded)
Remove port on NAT/Firewall when exiting = enabled
add tag to new task…=enabled
disabled allocated disk space
add .bc! file = enabled
and so on with all them check boxes
Max concurrent downloading BT task number = 1
Max concurrent downloading HTTP/FTP task number = 10
Enabled DHT Network (and is green)
enable anti-leech = auto
Long-time seeding enabled on both
one last thing, my WAN is green showing the port is forwarded correctly.
please help me
Mandow
x (teehee)
Two WEEKS? Good Lord, how big is the file?
Meantime,this.
Your Global Upload Rate should be set around 29kB/s (80% of tested upload); that could buy you some additional speed. But for the small number of seeds this torrent has, as opposed to the number of peers, I’m not sure if you can expect top speeds.
450kB/s is pretty much your max line capacity but the torrent, probably, had much more seeds at that point.
Just remember not to stop/delete your torrent task, when you finish downloading (visualize your frustration from right now :smiley: ).
thanks gandalf, im pushing 150kB/s as i type this
as for the file size, its 5.65GB.
when im done downloading the file, im gonna seed the cr@p out of it
