Help Port Forwarding New BT HUB
Hi,I am trying to port forward my New BT Total Broadband Home Hub But Only Find Info on how to P/F The older black model I neeed how to for the new white wireless version,
Any Help Much appreiciated
Many Thanks… :huh:
OK I did it,Just to check though I seem to have more remote connections now than local is this OK
If you’ve got remote connections, then you don’t need to worry about this part of it. You do, however, need to make certain that you are otherwise behind a firewall. Only the BitComet listen port should be open (and such other ports as you’ve knowingly and intentionally opened for specific purposes, of course.)
