I am downing loading a file that is 381 mb. the download is going on three days. the download meter sais I have allready downloaded 487 mb and is 42% done . why or what is going on
It is possible you have downloaded alot of corrupt data.
If so, you may have a problem with your connection.
bit comet runs a hash check on each piece of data, and if it does not match, it is discarded and redownloaded.
