hey ive juz updated to .79 n all my downloads are gone! my whole freaking bitcomet list is empty now lol. can any1 help?
you should change your default download location to the one where your partial files are, or move the partial files to your new location.
Then restart each torrent, as long as the files are there, they will be checked (rehashed) and download will continue.
If it doesn’t, then you can do a manual rehash “right click” “manual rehash”
yay! it works thanks ![]()
