I used to know how to add a blocklist, but I forgot. Can anyone help me out? Thanks!
To be honest, I haven’t got a clue. I’ve neverseen a blocklist and there’s nothing on thw BC wiki about it
The old version of Bitcomet, from years ago, allowed for import of p2p blocklist in ipfilter.dat format, I recall. Now I can find the ipfilter file, but it’s in guarding.p2p format. The container file is ipfilter.zip. The link to the ipfilter file is found on https://www.emule-security.org/
That’s an emule add-on and not a Bitcomet one. It’s there ONLY when emule is activated
Yes, I am looking for the ipfilter.dat or how to install it or import the guarding.p2p as an extension BC can use.
At the risk of repeating myself, the blocklist is an** EMULE function** - not a Bitcomet one.
It's only there if and when the emule plugin is activated. It's also present if only emule (and not BC) is installed
