how to clean my
:smiley: HELLO HOPE YOU CAN UDERSTAND WHAT IAM ON WITH,WHEN I SEARCH FOR ITEMS IN SEARCH MODE ALL THE INTERNET SITES SHOW UP HOE DO I GET RID OF THAT HISTORY WITHOUT CLICKING AND DELEETING EVERY SINGLE FILE THANKS FOR ANY SUGGESTIONS :slight_smile:
I deleted your other thread. Do not post in all caps again as it is very rude.
Now try this program for cleaning your computer and various history files. http://www.ccleaner.com
Now for a registry cleaner: http://www.majorgeeks.com/download.php?det=2048
:rolleyes: Thanks for the info and and yes i shouldnt use caps locks thanks again :smiley:
I would just like to add that I and others I know have used ccleaner and it screwed our systems up.It deleted some essential files making me need to do a system restore.
I find Registry Mechanic v-good.
CCleaner is free and does a good job. Iโ€™m not trying to be mean or rude but its not the programโ€™s fault that you used it to deleted some important files. This is why you need to pay attention to your settings.
I accidently messed up IE7 beta 3 using CCleaner. But that was my own fault and I admit that. Lucky for me IE7 RC-1 and IE7 Final both can fix and did fix the problem I made.
I understand that itโ€™s down to me which files to delete but if like me your not that savvy it would be nice to rely on the program to choose the action necessary.
