How to Disable dialog box "Verify login program at startup"
Please guys administrators i want to stop entering password before programs start please help from A.W
1.Please Input Login Password
  1. A box to put in Password
3.Then Program Starts
This is what happens…
If you’re referring to bitcomet, then go to "Options>appearance>verify login password at startup>change password’
Then leave the field blank and save.
i’m referring to bitcomet. It’s not working!!I am so frustrated now wanna cry i wud try ur suggestion again
I entered the old password left out the others it works now thanks a million :smiley:
You’re welcome.
