How to enable encryption
All the FAQs I read say go to Advanced>Connections and enable it there, but I don’t see this option.
I’m using BC 1.21
Under Advanced, the only options I get are Disk Cache, Scheduler and Remote Download
Sorry about that. That was referring to an older version.
I’ve changed the Wiki to indicate the real location of the option, now: Options → Task → BitTorrent.
kluelos since you still use v.0.70 (or anybody else who does) can you tell us the location of this option in v.0.70?
Voilà! :slight_smile:
Thanks cassie.
Now, I’m wondering until which version that option kept staying in the same place.
Nevertheless I’ll add a reference in the FAQ to mention this location for older versions.
