This is it. Well, let’s hope DAEMON Tools’ and/or Alcohol’s creators will include support of this rare type of image to their products…
edit: Man, what were you reading this with? :blink:
Step 2:
After extraction, you may find an ISO image, .daa image or .bin. or .cue or .dat or .mdf (& .mds if .mdf file is present, but don’t worry about the .mds file, it is needed, but Alcohol120% will only see the .mdf file present)
These can all be further ‘mounted’ or burnt onto 700 mb CDs with a program known as Alcohol 120%.
Please note, if Alcohol120% cannot play the .daa file, use this application to open it:
<a href=“http://www.poweriso.com/" target=”_blank">http://www.poweriso.com/ [PowerISO mildly supports more formats than Alcohol120%, but we recommend you to use Alcohol120% since it is much more user-friendly and updated more frequently.]
Thing is this afternoon I looked up PowerISO on the net and was too cheap to pay 29 bux for it…Only with “Ceres” post I realized I had used a free Dload software for the movie…Why dont I use it for software to crack it…LMAO
I should really change my user name to Newbie-for-Life!!!
Alcohol 120% isnt reading the file that I have Dloaded…
You are welcome. And you really should more attentive to what you’re reading (that’ll save you (and possibly, some others) some time):
(color changed by Const2k)
Well, you’ve read this at least twice before posting, so I think I should remind you one more time. READ the FAQ before posting.
