i need help ???
i download bitcomet 0.74 but when know its not stable i downgrade to 0.70 the problem is when i copy download folder of bitcomet 0.74 to folder download of bitcomet 0.70 bitcomet **didnt show the task of torrent ** please help me the size of file is 1:80 GB
You need to restart the torrent file just as you did when you first downloaded it.
If you have the partial files in the correct location, it will then scan (rehash) the files and continue the download.
If it does not, then do a manual rehash of the files (stop torrent, right click, and select rehash).
