I have been looking through my BitComet history, and there are several hundred downloads,
I'd like to seed them again, so how do I do it, I know where they are in a folder
Now another thing, When I shut down my PC, I have to open up bit Comet to restart the files I have downloaded
How do I start them as soon as my Bit comet is loaded ?
They go from Green to orange (Green not seeding, Orange Seeding)
Thanks in advance
Check in Options > Tasks (there is a setting to auto-resume files)
I’ve tried it, couldnt find anything, can you tell me more ?
/monthly_2022_06/Untitled.jpg.7b5347bdc56edafe05fd810f89308cf1.jpg" class=“ipsAttachLink ipsAttachLink_image”>
Yup, all those boxes are ticked
I hope when I restart Bit Comet, they will resume
And I hope someone will want the files I have downloaded
That worked fine
600 odd torrents redownloading, but by God, its slowing down my PC
The pop up box is going crazy, one every second
My poor old windows 7 PC is going mad😃
Oh, well its staying on all night, give em half a chance of downloadin
(I'm not sure why they are downloading them again, they are all in my downloaded folder, oh well its Bit Comet and a PC, I guess they know what they are doing)
Reduce the ‘maximum number’ for tasks and it will download that number simultaneously and it will queue the remainder and start as soon as an empty slot appears.
If the files are already there, check the folders and stop all transfers and do a manual hash check on all files, then restart
My hard drive is now full, I cant stop anything downloading now
I'm going to have to delete some of these files, so much for reseeding them
There is absolutely nothing anyone here can do about that beyond suggesting you get an external hard drive and transfer anything you really want to keep to that
You can stop any download at any time, irrespective of the amount of free space available - it doesn't matter how full the drive is - it simply stops any data from coming in and doesn't write anything to the drive from that point
I have now got an external hard drive and changed the location of downloads to there now, maybe job done
thanks for sharing your files
