iPod converter
hello I d/l the free-ipod-video converter… but half my files wont convert it says “missing video stream” so i d/l a trial of something else “imtoo ipod converter” it works but i can only convert 5 minutes its a trial version. anyone know where i can get a GOOD ipod converter for movies for FREE? thanks!
If you don’t mind watermark,you can try winavi ipod video converter. It has trial version too,and allow you convert whole movie.
Slysoft Clone DVD Moble & Slysoft AnyDVD will do the job for you.
www.slysoft.com
see if theres a torrent for a pay version that you dont need a license number etc for i did it with xplay for ipod instead of itunes and worked fine
The best converter out there (only free one i’ve found) is videora. Google it and download from its website its free, fast (700-800kbs) and it converts almost everything to ipod compatable format!
I’m downing it…
thanks very much!
