Please refer to IRC Channel Info for info regarding this.
Anyways, please post your comments here! ![]()
Kind Regards
Soraiya
Kind Regards
Soraiya
IRC is always going to be better than any shoutbox. For a start it is there all the time and you can go back through as many lines as you want. It also doesn’t constantly have to refresh the page. It is simple to chat for anyone. They can either use their own client such as mIRC or through a java link from site.
Soraiya, as you probably remember I have discussed this when we were at Seedler.
The server we use at TorrentMatrix is irc.p2p-network.net. We have used this and area51 for 2 years now and other than the occasional netsplit we haven’t had any trouble with it at all.
The staff are always available (well almost) and idle in all channels so that they are reachable. There are also their own channels if you need to contact them directly
hey Johno m8, Nice to see you here… ![]()
Haha. You can’t escape me. Wherever you go I’ll find you Suspect ![]()
im hv been using IRC for a long time.did u hv set up channel?if no,i recommend u using DALnet server…any question?
Kind Regards
Soraiya
I vote yes for irc channel and i will be ok with every server no matter which you choose. with the irc channel the problems could be solved many times faster.
everybody please join BitComet in dalnet server for help n discussion…
i have been set this channel…
I think an IRC would croud the problems, each user has like 100 problems (trakers, lounge, hellos,bittcomet,announcements)
well i cant find it besides i am waiting the support team to reg a channel so it to be official
So bitcomet support team when we to expect a bitcomet irc channel
it can be opened for seconds and at least 1 support member at a time to be online there to help and disscuss and thats it.
quys can anyone tell have to make your own torent work
, i tried but cant do it, plz answer :rolleyes:
u cant find it?y cant…
type below:
/server DAlnet random server
and then type below:
/join BitComet
well, the link in the first post contains no info on connecting to this IRC channel and i dont see any info here in this thread either… =\ how am i meant to enter this IRC that does not seemingly exist?
edit 1: xD the last post in this thread contains the info needed… maybe make note of it in the starting post?
edit 2: surprisingly, no one else is there xD
Having an IRC channel for BitComet is truly a great idea!!!
But, the channel no longer exists, right? ![]()
Any chance of getting it back on?
