Hello, My Listen Port is YELLOW and I am using Windows 10. Tell me how I able to make my port GREEN.
and secondly I have seeds on my torrent and it stop downloading. WHY ? I need help on this please.
Regards
-Fahad
Regards
-Fahad
Check that the port is open in Windows Firewall and matches the port in your router/modem
I am using Wifi, I don’t use DSL… And In Windows 10 how i able to check “Windows Firewall” ? Please Guide me
Control Panel > Windows Firewall > Advanced Settings
You still need to make sure that your computer port matches whatever port your modem/router is using (whether the wireless router is connected to DSL/Cable or whatever) and that your wifi ports match
most port problems on wifi are router settings. Can you connect direct to the modem with an Ethernet cable to see if the port is still blocked? if its open when connecting direct, then you will know it’s router settings, not firewall.
bitcomet should setup windows firewall automatically, it's pretty good at that, but setting up routers using UPnP is hit or miss since they don't all follow the same rules.
It says in RED Cross Circle " Inbound connections that do not match a rule are block"
Rest of them are all GREEN only " Inbound" connection is BLOCK.
And When I allow Inbound it says FIREWALL Is Turn OFF ? Now what to do ? :S
Open Windows Firewall in control panel and ‘Allow an app or feature through Windows firewall’. Go to ‘change settings’ and ‘add another app’
34 minutes ago, Rhubarb said:
Open Windows Firewall in control panel and 'Allow an app or feature through Windows firewall'. Go to 'change settings' and 'add another app'
I can see the Bitcoment.exe in "change settings" There are two tick marks options "Public" & "Private" I tick both.
I know it should but only if the OP actually told it to (it’s possible that he clicked the wrong thing and blocked it instead of allowing it - I know I did that accidentally with the BIOS flash app), but from his last post it doews sound as if it had been blocked.
NOW How I open my PORT ? I Try everything
Please read here.
/profile/824-cassie/?do=hovercard" data-mentionid=“824” href=“/profile/824-cassie/” rel=“”>@cassie It will also work on Windows 10 Pro ?
