LT-seeding and CometID
Hi, I have a rather simple question, but I don’t know if this is the right place to ask it. Do LT-seeding uploads count for your CometID score? Thanks in advance.
What’s the score calculation rule?
BC Score = Points from online time + Points from uploaded Bytes.
Being online can generate 2 points per hour, with a limited maximum of 20 points, per day.
** Uploading files continually, via BitTorrent protocol, can generate 1 point per 10MB, with a limited maximum of 100 points, per day.**
Downloading files, via BitTorrent protocol, doesn't affect the Score. The same applies to HTTP and FTP protocol.
The Score will be refreshed every 24 hours.
Actually I’m not 100% sure if LTseed uploads are counted the same as bittorrent uploads. Zerojinn, can you get an answer to this?
Yes, TUUS. LT-seeding uploads count for the score just like bittorrent uploads.
This is the answer given by the development team. :slight_smile:
I’ve updated the Wiki to reflect that.
Thank you wiz! :rolleyes:
Thank you all!
