The mouse randomly crashes while connected to the internet, after research I found that when exiting bitcomet this problem ends. Thanks.
BitComet has nothing to do with the mouse. Check your drivers or re-install them.
It also may help if you check your hard drive and pagefile. Run chkdsk/f and defragment it
Oh and don't use large type - it spreads out past the screen edges
