I just noticed that all movies where playing reversed. Everything is playing as a mirror image. I no this is a software problem. Reinstalling MPCstar did not fix the issue. Does anyone have any ideas.
There seems to be an issue from the ffdshow software. It works pretty weird. If I use the “Mirror” option from the “Offset and Flip” page of ffdshow settings, on a video nothing happens.
But if I enable it and then start another video which comes before the actual one in the playlist (in fact it’s a fake entry, because the video file has been moved) then MPCStar jumps to the next video in list (the one I was testing one) but this time with the “mirror” option enabled!
Again, in order to disable it I have to do the same move, since it won’t disable it directly (it seems to have no effect if I just disable the option and the restart the video in question).
This same behavior goes for several videos I’ve tried.
This looks like either a ffdshow bug or a bug in the communication between MPCStar and ffdshow.
Lucy, can you please check with the team on this?
Guys have you tried Video → Video Rotate → turn 180 or Flip vertical in MPCStar? It may helps.
Hehehe… I’ve totally missed that setting. ![]()
Nevertheless, the oddness of ffdshow behavior still stands for me. This setting above, was disabled for me.
Wizard did you mean the movie is still in a reversed image even you turned it 180 or flipped vertically?
