need help with playin movies
hello there can any1 help to play a downloaded movie the movie is get rich or die tryin dvdrip.xvid-deity also wot is the best software on how to play downloaded movies need a software for other files thnx
1st u should install XVID video codec seems ur video file is encoded with that codec
as for the best player, i would suggest VLC player where u can find it at http://www.videolan.org/vlc/
dont have a clue how 2 work it soz
huh…get xvid codec here → http://www.free-codecs.com/download/XviD_Media_Codec.htm
n read the instruction
If you are using VLC Player you do not need to install codecs. VLC won’t use them because VLC only uses internal codecs.
So either get VLC or CCCP.
