Halp plz n thx ![]()
The version of BitComet is 1.37
The version of Windows is 7 type 64 bit
My connection is ?? my router is ??
My port is ??
^ not sure if “??” are needed, if they are, pointers to grabbing that info is much appreciated.
Recently I moved my save path to my external hard drive (standard WD elements 1 TB drive), as well as moving the files that I’m seeding for there.
Now, for some reason, I’m getting 0 kbps up and 0 kbps down; here’s a screenshot: https://www.dropbox.com/s/iw8j60963682huv/capture.PNG?dl=0
Any troubleshooting suggestions would be much appreciated!
In addition to this; I’m curious what the bracketed numbers mean in the (seeds/peers)[??/??] column; in the column header it says (seeds/peers)[all] … if i’m seeing [0/240] or etc., does that mean that there’s 240 people associated but 0 of them currently active?
Thanks again.
