No download when using Anonymous Download
Essential Info:
  1. BitCometBeta 20110516
  2. 3G HSPDA wireless internet, Telstra Australia. And also tested with Telstra adsl2.
  3. Sierra Wireless AirCard® USB 306 modem (ISP supplied and configured), direct usb connection to computer. No router or connection sharing. Also tested with zyxel p-600 modem over ethernet.
  4. I have a PC and a notebook. I plug the modem into the one that I am using at the time. They both suffer the same problem. Tested the notebook on the other network (adls2).
  5. Windows xp sp3. PC has AVG and Zonealarm, The notebook does not have any firewall or antivirus software, xp firewall disabled.
  6. I have tried a variety of torrents from different sites.
  7. Speed test results are in the 2.5-3 megabit/second range.
I can download very well with regular torrent download and VIP download. When I enable Anonymous download, only 1 out of about 10 torrents will work. The torrents that don’t work with anonymous download, they do work without anonymous enabled. The torrents have hundreds of peers and leeches, with working trackers.
I have tested anonymous download on a different computer/isp type/location with my account.
Edit: My Listen Port is open, green light.
Thank you for your report. If you could upload some of the torrents that aren’t working I’ll see that the development team gets them.
I’ll also reply if there is any further information they require to help troubleshoot this issue.
Could you clarify what you mean by “they don’t work”? Do you mean that the torrents never download, or what, exactly?
I just want to make sure you understand that anonymous download is in opposition to normal bittorrent download – that if you choose anonymous, you disconnect/turn-off normal bittorrent because that would defeat the whole purpose of anonymity.
Thank you for the fast replies guys.
The UnUsual Suspect: Can I PM you the torrents?
Kluelos: Apologies for the abstract description. When I open a new torrent, in the Task Properties window I click on the VIP acceleration tab, click enable VIP accelaration, then tick the Enable Anonymous Download box, then click ok. The torrent appears in the list, with the green arrow to indicate it’s running, but it receives 0kB/s download, and it achieves 0% progress after waiting hours.
To test it isn’t just a bad torrent I have tried adding a new torrent, enable VIP but NOT Anonymous download, and only select one or two of the files contained within the torrent. These files download without issue. I then go into the task properties of that torrent, select the remaining files of the torrent to be downloaded, and then enable Anonymous Download. The progress % changes from 100% to a lower percentage to reflect that more files are needed to be downloaded. But after enabling Anonymous Download, it will not download any more data, none of the remaining files of the previously working torrent will receive any data.
I hope this clarifies the problem. Any further questions don’t hesistate to ask.
Thanks.
The UnUsual Suspect: I have just PM’d a list of 6 torrents that do not work, and 1 that does work.
Hi travisbevo,
when you click the VIP section as the picture, what can you see?
/monthly_06_2011/post-62477-13085568327532.jpg" rel=“”>
There are two kinds of status : one is ready, the other one is preparing. There is no speed when its preparing.
/monthly_06_2011/post-62477-13085569232429.jpg" rel=“”>
Hi Zerojinn, the torrents which haven’t worked say “Preparing”, even though some are more than 24 hours old. The 2 that have worked are in the list as “Ready”.
Yep I am having the same problem as the OP.
Edit: Mine just started working again!
Ikim65, happy to hear yours is working again. The problem remains for me.
I did not receive any PMs from you.
I have resent it. I think I sent it to Kluelos instead, because I have received a reply from him.
Sorry, I wish I could give you a solution but mine just started on it’s own so I have no idea what the problem was in the first place. The only thing I did was stop and restart the torrent several times and then it just started working again.
it is possible that there wasn’t a server available at the time you tried to start it. We have been adding servers to keep up with the rising popularity of the service, but the possibility of a surge in users could adversely effect the performance. Hopefully our efforts will minimize these occurrences.
I can easily duplicate the problem.
The torrent just sits there “prepering”, forever.
It seems clear to me that VIP download needs to give a lot more feedback to the user than it does - similar to the feedback that you get from a tracker, about what’s going on, what problems were encountered, so that the user knows what to expect or what to do.
That’s good to hear it’s not just me.
I passed this on to development. I think it’s a great idea, at very least the user should be notified if there are no sources available for the task. Bittorrent protocol has always relied on the users knowledge of the seeds/peers column, but it would be nice if a user was warned when starting the task and given chance to cancel the vip on that task before it begins if it’s not likely to complete.
Just to confirm, this isn’t the problem for me though. The torrents I’ve sent you as examples have hundred of seeds/peers, and will download very well without anonymous download enabled.
Actually, the first smaller one you sent, did have a problem, and would not complete. It stopped at 99%.
Because of the complete lack of information with Anonymous download, I was unable to even guess why that was. I had no idea how many peers there were, whether it could complete or not – meaning whether I would be wasting the VIP bandwidth or not, whether it might be a plant or a fake.
Other torrents that I have experimented with though, DO have this problem – as normal downloads they’ll progress along nicely, but as VIP downloads, they sit there, preparing, for days, until the normal download is complete at the normal speed. Since I can’t delete tasks in the VIP list, I guess they’ll stay that way forever.
@travisbevo, I knew that isn’t the case with your torrents, but felt that would be a first bit of info the vip system would need to check and report to the local client.
It’s good that we’re finding these things, this is what beta testing is all about.
That’s good, just wanted to confirm.
