No puedo acceder a mi cuenta en bitcomet
Buenas, tengo un problemita con el bitcomet, hace dos dias que no me deja ingresar a mi cuenta, solamente pongo ingresar y se queda cargando y cuando clickeo en acceder aparesco como si estuviera conectado en la pagina del bitcomet.
Hello, I have a little problem with BitComet. For the last two days, it hasn’t allowed me to log into my account. I only click on Enter it remains as though loading and, when I click on Access, it shows as though it was trying to connect.
There was a server problem but it was corrected today. Please try restarting bitcomet and you should be able to sign in.
Había un problema con el servidor pero fue corregido hoy mismo. Por favor, reinicia BitComet y verás que podrás acceder.
no me esta dejando loguearme con comet id
It’s not allowing me to log in with CometID.
cometid server has been intermittent all weekend
Al parecer, el servidor de CometID ha estado de forma intermitente, todo el fin de semana. Estoy segura que se resolverá tan pronto como sea posible.
It seems that the server has been working intermittently all weekend. I’m sure that it will be fixed as soon as it is possible.
Thanks for heads up. :slight_smile:
Hola , no queria abrir un nuevo hilo , tengo el mismo problema no puedo loguearme al abrir el programa , desde hace 3 años masomenos cambie de version tambien formatie pc ,estaba con logueo automatico, en ese tiempo no tuve problemas al descargar solo que no loguea en consecuencia no suma puntos ni sube de rango soy usuario de bit comet desde 2009 ,tengo la version 1.4 64bits muchas gracias por alguna pista
Hello...I didn't want to open up a new thread... I've got the same problem - I can't log in upon opening the program. About three years ago, more or less, I changed the version and formatted the computer. I had enabled BC to login automatically.
Since then, I don't have any problems downloading but, since it doesn't login, it neither adds the points nor allows me to increase the level.
I've been a BitComet user since 2009. I use v.1.40 64-bit. Thank you very much for any hint.
ComitID seems to be working now
El CometID parece estar funcionando correctamente ahora.
no puedo conectar con el servidor del comet id
hace más de dos días y estoy perdiendo puntos con eso
I can't connect to the CometID server, since two days ago, and I'm losing points because of it.
does this problem still exist?
¿Sigue existiendo este problema?
