Not loggined in?
Hi! i have a problem- I’ve just install Bitcomet 0.71, but I have a message in the program’s bottom “NOT LOGINNED IN” and I can not download any files… What Ihave to do now? Please, I wil be very gratefull to any help. Thank you
even M facing da same problem..some 1 pls hepl us out with its solution..plzz reply.
yup, same here.
i have no idea what that is - whatever it is, it’s causing many hang ups
yeah..i have the same pro
why is that even there?
me too :unsure:
what i see … as a result of this problem, is that it doesnt effectively or correctly show the download process.
so even when it might be downloading, it still says connecting.
or it doesn’t show how many % has been going down.
strange. why’d they fix what wasn’t broken!!!
I have the same problem as you mate, it might be an idea to download the older version of bitcomet or just wait and find out what they will do to fix it.
At the moment just ignore it and keep downloading like normal. However, if you’re having more problems you might want to go back to 0.70 for the moment.
I got the same message: ‘not loginned in.’ (Same spelling…) with 0.71. I uninstalled 0.71 and installed 0.70 and everything is working again. (My downloads had all stalled, nothing was happening…)
Odd message, odd spelling…
