I have a problem downloading and installing your software. this is the massege i get:
NSIS Error
Installer integrity check has failled, commen causes include incomplete download and damaged media. contact the installer’s author to obtain a new copy.
more information at:
http:/nsis.sf.net/NSIS_Error
I also tryed cnet download.com to get Bitcomet! same error.
Regards,
Tareeka
- download new setup package: http://www.bitcomet.com/doc/download-achive.htm
2.check your disk for bad sectors.
3.check your OS that your computer’s security settings properly.(Try the following methods carefully)
copy the following text into a .bat file and then execute
“reg delete HKLM\SOFTWARE\Policies\Microsoft\Windows\Safer\CodeIdentifiers\0\Paths /va” (removing quotes)
gavin, must this work on the real HKLM key?
Because if he has Vista or Win 7 with UAC on, and runs that .bat file, he’ll get redirected in the VirtualStore key, isn’t it?
Or it doesn’t matter because that’s where you mean it to write?
Only redirect some security settings.
I’m not sure that is effective.
