You have a firewall blocking your listen port. Since we aren’t there to investigate your system, it is up to you to find the firewall(s) in question.
Firewalls can be software, running on your machine. Software firewalls have no way to be aware of each other, so it’s quite possible that you have more than one running, and you may not even know about all of them.
Firewalls can be firmware, running in the hardware you own that connects you to the internet. This can be a router, it can be in some modems, it can be in switches or simply access points. Any of these might have a firewall. Almost all routers do, the other devices less commonly so.
Firewalls can be external. Your service provider may have you firewalled, and you usually cannot do anything about that or control the firewall you’re behind. Almost all wireless connections of whatever kind are firewalled. Very often, internet connections that come with the facility – office, dormitory, apartment, hotel – are firewalled.
You can easily have multiple firewalls of different types, without knowing it. Multiple firewalls do not make you safer. They just cause headaches because anything that is done to configure one firewall must be done to all of them. On the other hand, you must have at least one firewall. Never, ever connect to the internet without a known working firewall.
It seems likely that you have not properly configured Norton to allow incoming traffic on your listen port. I discommend all third-party firewalls such as Norton, and suggest that you not use one. The built-in windows firewall is all you need, and BitComet will configure if automatically if so set. Norton’s other capabilities, like its antivirus, are ok, but you can get free products that are much better behaved.
You need one firewall. You should disable/uninstall all of the others if you can. if you cannot, or chose not to, then you must configure all of them to allow incoming traffic on your listen port. If you cannot do this, then you will have to simply tolerate the resulting slow transfer speed.
Ai un firewall care-ti blocheaza portul de ascultare. Avand in vedere ca nu suntem acolo sa-ti investigam sistemul, trebuie sa gasesti tu paravanele in discutie.
Paravanele pot fi software, ruland in calculatorul tau. Paravanele software nu au cum sa fie constiente de prezenta altora ca ele, asa ca e foarte posibil sa ai mai mult de unul, si e posibil ca tu sa nu stii de toate.
Paravanele pot fi firmware, prezente in aparatura detinuta de tine care te conecteaza la internet. Acesta poate fi un router, poate fi in modemuri,poate fi in switch-uri sau pur si simplu puncte de acces. Oricare din acestea poate avea un firewall. Aproape toate routerele au, celelalte dispozitive mai putin.
Paravanele pot fi externe. Distribuitorul tau de internet te poate pune in spatele unui paravan, si de obicei nu poti face nimic in legatura cu asta si nici sa controlezi acel paravan. Aproape toate serviciile wireless, de oricare tip sunt in spatele unui paravan. Foarte des, serviciile de internet care vin odata cu spatiul – birou, dormitor, apartament, hotel – sunt in spatele unui paravan.
Poti avea usor multiple paravanuri de tipuri diferite, fara sa stii. PAravanele multiple nu te fac mai in siguranta. Ele doar cauzeaza dureri de cap deoarece orice faci la unul din ele, trebuie facut la toate restul. Pe cealalta parte, trebuie sa ai cel putin un firewall. Nu te conecta niciodata, in veci, la internet fara un firewall cunoscut, activ.
Cel mai probabil nu ti-ai configurat paravanul de la norton pentru a da voie conexiunilor de intrare pe portul de ascultare. Nu-ti recomand paravanele personale cum e norton, si-ti sugerez sa nu folosesti unul. Paravanul incorporat de la windows este tot ce ai nevoie, iar BitComet il va configura automat daca e setat sa faca asta. Celelalte capabilitati ale lui norton, cum ar fi antivirusul sunt bune dar poti gasi alte aplicatii antivirus gratis care se comporta mai frumos.
Ai nevoie de un singur paravan. Opreste/dezinstaleaza restul daca poti. Daca nu poti, sau nu vrei, trebuie sa le configurezi pe toate sa dea voie la traficul de intrare pe acel port de ascultare. Daca nu poti sa faci asta, va trebui sa tolerezi vitezele mici de transfer rezultate.
