hiya, i accidently removed the top toolbar from my page (as in the 1 with , file, view, history, bookmarks, tools and help) can any1 tell my how to get it back please.
your, feeling thick, antk1090 :(
help please!!
under the VIEW menu, mouseover Toolbars, and select the ones you want.
You really ought to do a little bit of exploring on your own before running for help.
Kluelos, I guess that’s exactly the one he lost (menu bar). :rolleyes:
@ antk1090: You can hit the ALT key to make it visible first, then do what kluelos told you.
Another quick solution is to right-click on the thin space between the address bar and the title bar (just above the address bar) and select Menu bar.
