Options menu for emule plug-in has lost text
Any way to adjust the fields for the emule plugin options settings menu, it’s all jumbled at the text description area? Been that way forever, it’s too easy. Thanks!
It needs a dev to go in and adjust the perm parameters of the options menu page. Next version, in the recompile.
And possibly give us the option to select 'file finished mm/dd/yr', as a column on the Torrent History Menu from the left column inside BC.
If you right click on the task bar, there are a lot of options that can be added: ‘added on’, ‘finished on’ and ‘torrent created on’ are all there - just select the ones you want
