Piece size
I have problem with my wifi connection during hot summer weathers (many crc errors), so when i download something bigger than 1Mb it is always corrupted. The only way to download something is to use BitComet (thank you very much for that). Problem is that if piece size is low, im able to download with only 10% of garbage data (piece size 128kb), but when the size is greater than 512 it is around 50-60% of garbage. Is there a way to set a piece size? (any advice helps)
No. The piece size is established when the torrent is created, and can’t be changed.
Try using a different channel for your wifi connection. Some older wireless telephones use the same band and can interfere with wifi.
