Starting from last week, i found out my bit comet occured a problem.
The download speed decreases significantly. I am using 2MB ADSL, normally the average fast download speed i have is 160 KB/s , but ever since two weeks ago, The fastest speed i reach is only 65 KB/s,
*I normally download from animesuki, so the torrents i download have many seed and peers,
but the speed is still only 65 KB/s , how can I get my speed back
*at first i assume this is my ISP problem, but when i try http download, i got a speed of 160 KB/s ,
why is it like this, can anybody help me?
p.s I tried other bit torrent client, but my speed is still lower than 65 KB/s ,
force encription in BC settings
your isp is probably limiting p2p
then what can i do about it, if my isp is limiting p2p, what should i do?
is there any setting in bit comet to solve the problem?
*also why i was able to get 160 KB/s for the last two years if my isp is limiting the p2p.
Because your ISP wasn’t throttling you before? The problem suddenly started two weeks ago?
yah, this just happen two weeks ago until now. I have been using bit comet for more than 2 years, and this is the first time i encounter this problem. I ask my ISP already, they did not limit anything.
why is my bit comet download rate only 40 KB/s while http download (like download.com) is like 160 KB/s.
Can someone please help me
I don’t know. You seem pretty dense. But we’ll try a third time here:
That means and meant, go in to your bitcomet settings, in the advanced/connection section and set protocol encryption to “always”.
