Salut! Scuze de intarziere, am fost foarte ocupat cu seviciul…
Ce ai tu e un stick wireless de la RDS. Toate conexiunile ce vin spre tine sunt blocate de RDS, pentru a nu supraincarca reteaua celulara. Nu ai cum sa deschizi portul.
Nu exista internet prin modem stick cu porturile deschise la ora actuala, pur si simplu le impiedica tehnologia profitul.
Hi! Sorry for the delayed response, I’ve been very busy at work…
What you have is a wireless stick modem from RDS. All incoming connections are being blocked by them to prevent an overload on the cell network. You can’t open your port.
There are no unblocked internet connections via a stick modem to this date, it’s simply that the technology is impairing their profits.
Am aceeasi problema…cu portul. Folosesc un modem Huawei K4510 cu viteza foarte buna,..cu pachet de date de la Vodafone. Windows 7 home premium si un avast 7. Am verificat si firewall-ul…si nimic. Nu descopar ca ar fi in neregula.Am incercat inclusiv toate optimizarile pentru Bitcomet ce le-am gasit pe topic! Si totusi downlodez cu 1kbit!..Sper sa gasesc un sprijin pe acest topic…multumesc.
The type of internet connection you’re using doesn’t allow for incoming connection attempts so you’ll always be firewalled. Vasy has told you this. If you want to use p2p downloading efficiently, you’ll need to get a complete internet connection that doesn’t have you blocked from remote peer connections.
Va salut!Sunt nou pe acest forum si am si eu aceeasi problema cu portul de ascultare…este in galben.Am facut setarile recomandate in firewall si bitcomet …dar degeaba
Eu am internet prin sweech de la cineva… nu folosesc modem.Ce pot sa fac…sa devin verde…
