possibly not working right.
I bought the VIP because my ports are blocked due to not being able to access my colleges router to forward my ports. So this tends to be a problem when i download a torrent. Most get to around 90% and then stop, either not downloading anything, or, downloading but not raising the total percentage up. This is quite annoying. So i bought the VIP. I am sure that this helped me out a lot but it still seems in some cases even tho there are like 200 seeders, it still stops. And the VIP is not helping it at all. magnet:?xt=urn:btih:CUDFBFL2M3YSYFI5L6HNKU77YOBEDAFZ&dn=Korn%20-%20Discografia%20%5Bwww.emwreloaded.com%5D&tr=http%3A%2F%2Ftracker.torrentbay.to%3A6969%2Fannounce&tr=http%3A%2F%2Ftracker2.istole.it%2Fannounce&tr=http%3A%2F%2Fgenesis.1337x.org%2Fannounce&tr=http%3A%2F%2Fbt.rutor.org%3A2710%2Fannounce&tr=http%3A%2F%2Fbt.firebit.org%3A2710%2Fannounce&tr=http%3A%2F%2Fcpleft.com%3A2710%2Fannounce&tr=http%3A%2F%2Ftracker.desi6.com%3A7979%2F8zfhzilwff8o883kjn84vxzrae0s52jd%2Fannounce&tr=http%3A%2F%2Ftracker.xdvdz.com%3A2710%2Fannounce&xl=1091972898
Not sure if thats the correct way to post it or if that helps but its the magnet url for the torrent.
Is an example, im stuck at 87.1%. What can i do and what is the problem?
Thanks in advance guys!!!
Lack of an open listen port does not cause a download to stop at 90%. Rather, it greatly slows your download speed for the entire torrent, but will, ATBE, finish the download.
Torrents that don’t finish are an entirely different issue, not related to whether the listen port is open. The factors that prevent a torrent from completing, won’t be changed by using VIP. You should refer to our FAQ for more information on the issue.
