Alright so I downloaded and installed Bitcomet then this popup pops up and tells me i should instal a font pack for Bitcomet to run efficiently, so i installed it and now the text in some of the popup messeges from other programs is blanked out. does anyone has any idea how i could fix this problem?
U got owned by adware. My best choice is to scan your comp clean then reinstall bit comet.
first of all what version of bittcomet are you ussing?
second? pop up messages blanked out?(from other programs) hmmm i don’t know about this?
Do you have a firrewall and a antivirus on youre computer?
I really don’t know any solution 2 this problem…
BitComet itself should not require a font pack for any reason. I suspect you downloaded a hacked version that someone included adware with, and the font-pack was for the malware.
I’d suggest you uninstall and delete BitComet, scan your system with AdAware and Spybot S&D, then download BitComet 0.70 from the primary site. You can find it here: http://www.bitcomet.com/doc/download-achive.htm
