Proxy monitoring
i am using bitcommet client. In my organisation we are using Webmarshall proxy. Whether this proxy monitor download/upload by bitcommet ???
The product does not explicity say so, but it probably does. If they’ve bothered to pay for WebMarshal, they’ve probably also put policies in place that forbid bittorrent, so you probably want to make very sure of that before you risk your job.
Thanks, but whether it can identify which type of file i am uploading/downloading or only it can monitor the tracker which i am connecting
Since it says it will filter files based on type, then yes, it almost certainly can You may be able to defeat this by setting encryption to “always”.
