I installed Bitcomet on 2 PCs at mine for several years now.
Today I updated both of them to 1.20
On one of the PCs I can still download like before
On the other PC I can’t connect to the server and can’t download
I must say I haven’t been downloading on that 2nd PC for a long time, but I did long time ago.
Both PCs are running XP-SP3.
Services running are:
Avira Antivir Guard
DHCP client
Event Log
Plug and Play
Print Spooler
RPC
System Event Notification
Security Accounts Manager
COM+ Event System
COM+ System Application
Cryptographic Services
DCOM Server Process Launcher
Network Connections
PCP/IP NetBIOS helper
WMI
Windows Audio
WIA
Workstation
I connect through a LAN to my router (ADSL broadband) and this message has been written on that PC (so I do have internet connection on that PC)
Settings for Bitcomit:
Listen port 13176
Add windows Firewall exception
No proxy
Enable eMule plugin listen port 15264
Check if port is forwarded properly automatically
I just can’t download despite the message:
"Unable to sign in it Cometpassport at this time
You can still download, but your rank and score points will not be collected"
What is wrong and what can i do about it?
