se conecteaza
Salut,
Dupa reinstalarea OS(WXP),uploadul imi arata mereu"se conecteaza".
Cu conectare manuala, face la fel.Care ar fi problema, ca vreau sa-mi imbunatatesc ratia.
Hi.
After reinstalling my OS (WXP) the upload shows “Connecting…”
It does the same with manual connect. What could be the problem, because I want to improve my ratio.
New Microsoft Word Document (3).doc (107 KB)
Salut!
Ce vezi tu acolo iti arata faptul ca BitComet cauta si incearca sa se conecteze la alti parteneri. Nu e nimic anormal sa stea mult in starea asta daca nu sunt parteneri disponibili pentru acel torrent. Apropo , ai deschis portul de ascultare pentru BitComet? (Ai un indicator in coltul din dreapta jos al ferestrei BitComet, ce arata? wan sau blocat?)
Hi!
What you see there indicates the fact that BitComet is trying to find and connect to other peers. It is not abnormal if it stays a lot in this state if there are no available peers for that torrent. By the way, have you opened your listening port for BitComet? (You have an indicator in the lower right corner of the BitComet window, what does it show? Wan or blocked?)
Am atasat un print screen, sper ca se vede ceva
I attached a print screen, I hope you can see something.
Data viitoare ataseaza-l ca poza, preferabil JPEG sau PNG.
OK. Mai fa unul cu sectiunea “Logs” selectata. Apoi citeste asta
Next time attach it as an image, preferably as JPEG or PNG.
OK. Make another one with the “Logs” section selected. Then read this.
