“Set as Default Directory” does not stay set
Issue: In the “Create new BitTorrent task” dialogue – I select an option from the “Set as Default Directory” list – the “Save path:” value gets updated correctly, and the item I selected in the “Set as Default Directory” gets a check mark - However, if I make this selection before the file list of the “Torrent Content:” section of the dialogue gets populated (this can take a few minutes sometimes) the “Set as Default Directory” value gets reset when the file list does finely get populated. The “Save path:” stays set correctly, but I have to reselect the “Set as Default Directory”.
Expected result: I would expect this value to stay set to the value selected until I change it.
BitComet (64-bit) 1.96 / Windows 11 Home 64-bit
Thank you in advance,
Mike
