Speed setting
Hello there,
I have difficulty setting up the DL and UL speed for Bitcomet from my internet carrier.
My UL speed is 490Mbps and UL speed is 540Mbps from speed test.
I run 5 torrents at a time, it is always frozen when it reach 99.99%.
Sometime the program will "not responding". When i stop some task it will show "yellow" and hold a for a while.
My PC is an I7 with 10700 CPU 2.9 Ghz, 16 RAM and 64 bit Windows 10 system.
Beside the setting for speed, any other setting i need to setup , please advise.
Thank you.
That’s an issue that cropped up recently and has been reported to the devs. We’re just going to have to wait until they look into it and (hopefully) fix it.
Short term - exit the progrem (from the menu bar) and when it's completely stopped, restart it. In most cases that will kick in the download for the final few bytes
get it,thx
