I have a Westell 327W router, and I’ve forwarded my ports that I’m using for Bitcomet as well as set up a static IP. However, my connections are still all local. What should I do to fix this problem?
first, go to canyouseeme.org and test your listening port.
if it tests anything other then open, then you have done something wrong.
