Torrent Sites
When I click on the left bar links for the listed torrent sites, it will open in Internet Explorer. I use Firefox. Can I set it so they will open in Firefox?
IE is integrated into bit comet.
I suggest you go to the sites directly from your firefox browser if you don’t want to use the integrated browser.
I personally like firefox alot more then IE, but that is just my opinion.
Perhaps you could post the request in suggestions section.
