Topic moved
Hi kluelos
- First of all ..Thank for your Brownser which I have been using for over 4 years without any problems at all .However , recently ,I had a trouble of downloading as DOWNLOADS box just pop up and downloading what I demanded and did not open fully to screen and i had to double click on the item in the Download box to open it out .
Before that when I downloaded something then this box will appear as :
Opening (…).pdf
You have chosen to open
(....).pdf
which is a : Adobe Acrobat Document
What should Cometbird do …?
.Open with A.R 0.3 (default)
Save file
Do this automatically.....
I got tire of this problem then I downloaded the Mozilla Firefox Brownser in order to get what i want .
Please , help me to fix this problem .
- Second of all , what’s the difference beetwen Cometbird and Firefox Brownser …?
Thank you so much
