Two issues found with v1.95
Beside the snapshot problem, there are two issues I found particular with the new v1.95:
1) Failure to transfer torrent task folder to a new location. I have to manually transfer the folder to the location I want in Windows Files Explorer and point the new location within the torrent task inside BitComet.
2) Opening .torrent files don't automatically open up a new task with BitComet. I have manually open the .torrent files with BitComet to add new tasks.
I should rewrite Point 2 more clearly:
2) Double click the .torrent files in Windows Files Explorer don't automatically popup a new task window of BitComet. I have to get inside BitComet to open the .torrent files manually then a new task window would popup.
Try right click and ‘open with’. You should be able to associate .torrent files with bitcomet in the browser
