VIP probleams ?
hello everybody i just bought the 10 g plan in the vip and i was wondering if there are any problems currently with the Vip service ?
because i am queuing for Vip on a torrent over an hour now and it doesnt seem to go anywhere
thanks!
Downloading can (and does) depand on the speed that the seeder/uploader is running. In the case of a popular file where there is only a small number of seeds, all transfers are split between the leeching systems and, if his upload speed is capped at a lowish level, then it takes even longer. It also doesn’t work if there are no seeds available.
It will download faster but it does depend on the upload being readily available.
You should also consider checking  [this post](/topic/12796217-vip-problems/)
