W.M.P. suckalooza
I’m new here so I hope this is where I learn how to program my new toaster…or how to make vlc my default preview player instead of w.m.p. which repeatedly gives me a redundant message about being out of date and it being impossible to make it not out of date, I’ve gone to windows ctrl panel and made vlc my default for everything there but when I try to preview in bitcomet it just keeps opening w.m.p. with that stupid message.
Any helpspeak would be full of help for me right now, I’m stuck.
																								   Thanks
go into bitcomet advanced settings and add the path to your vlc executable in the video preview option and it will open that pllayer. You can also add commandline switches if you want it to open with any special settings enabled.
Thanks Admin! I had the same problem like ifle.
Best Regards.
