WAN Blocked
I have just had to reinstall windows 7 professional on my pc since then i am now getting a blocked sign where it used to WAN then numbers obviously it all worked fine before my firewall is letting it through i have made sure of this please can someone help me my downloads are soooooo slow now any help would be great thanks.
Unfortunately no one here knows anything about your system configuration. I would be glad to tell you what information is required to begin helping you, but to save my sore tiring fingers I’ll just refer you to the “READ THIS before posting” topic that’s linked throughout the forum, as it lists all the required info you must provide.
Also note that any prior router settings may no longer apply since you have a newly installed operating system, so you may have to repeat setup procedure if your using one.
