Hi!
Where can i configure my wan ip adress (i have 271.165.xxx.xxx
) becouse i still downloading with low speed ( about 5kb/s)…thanks
Hi!
You can’t. Not with BitComet, or with any other program.
Your WAN IP is assigned by your ISP, either dynamically or $tatically, and you cannot change it. You will lose your internet connection if you try. Nor is there ever any reason why you should.
yes, thats true, i know that..
but bitcomet shows me LAN IP 192.168.X.X, and WAN IP is empty!
did you meant the other peers(other computer that uses the same torrent)? right?
or did you meant youre firrewall… I Don’t know about that but 1 question? what version of bittcomet are you ussing?
In most circumstances, you don’t need to worry about what it is, and BitComet doesn’t generally need to know either. It might be useful in a proxy situation but otherwise not.
