WebSeed for multi-file task
Hello. I have a question, which answer I can’t find on http://wiki.bitcomet.com (or the answer is not accurate enough)
How to successfully add WebSeed for multi-file task torrent? I want a plain example with screenshots if possible.
I’ve been trying to figure this out for a week. Now I give up, and I ask you guys.
Your help will be more than appreciated. Thank you!
Separate link for each file is required, must be a direct link to the file, not a link to a webpage, a link that actually downloads the file.
very small files should be archived together before the torrent is made and use one webseed link for that archive.
After download the files must be converted into bittorrent pieces so the task can complete, so the torrent won’t be about to complete 100%from webseeds alone unless all files have working webseed links.
Thank you for your response! I finally figured out.
