Websites passwords and bookmarks how to save ?
Hi,
Which do I need to keep in order to save my network passes and bookmarks ? I plan to copy and cut to another profile.
Thanks !
This you should ask at FireFox. Whatever the technique, it will work for CometBird as well. If they don’t know you may have to experiment.
Please use LASTPASS extension for firefox to store the passwords for various websites and for storing bookmarks, the best extension is XMarks for Firefox. Do check them as they are the best extensions. Hope it works.
Thanks a lot Khota.
Yes, I will check also to firefox forum
